TwinTurbo.NET: Nissan 300ZX forum - Sorry I didn't look sooner. I see the big 3 write up page!
gman300zxtt
on June 23, 2015 at 2:21 AM
Are all of the wires insulated well? Did you perform big 3
posted by flashstar
on June 23, 2015 at 01:56 AM
I have a small 16 gauge grounding kit from the 2 points on the plenum to the body. I might not being doing much
Help! why is my stereo turning off and back on again
gman300zxtt
14:15:27 06/22/15
Reconnect the AM head unit ground, and if you want
ttz'in (norcal)
16:29:04 06/22/15
Re: Reconnect the AM head unit ground, and if you want
gman300zxtt
17:46:45 06/22/15
Correct, you took the ground from the AM head
ttz'in (norcal)
19:12:39 06/22/15
Re: Correct, you took the ground from the AM head
gman300zxtt
20:22:14 06/22/15
Problem new, or since install ?
ttz'in (norcal)
21:44:25 06/22/15
Re: Problem new, or since install ?
gman300zxtt
01:47:18 06/23/15
Re: Re: Problem new, or since install ?
gman300zxtt
01:53:46 06/23/15
flashstar
01:56:56 06/23/15
Re: Are all of the wires insulated well? Did you perform big 3
gman300zxtt
02:05:31 06/23/15
No alternator is stock, no hair-pin style harness,stock
gman300zxtt
02:12:39 06/23/15
I hope you mean voltage, not ohms... ;)
flashstar
14:27:36 06/23/15
Re: I hope you mean voltage, not ohms..sorry I meant voltage
gman300zxtt
00:34:48 06/25/15
Sorry I didn't look sooner. I see the big 3 write up page! -
gman300zxtt
02:21:55 06/23/15
You may want to remove that extra grounding kit to test
flashstar
14:37:18 06/23/15
I do hear a little buzz when the music is on pause
gman300zxtt
00:40:08 06/25/15
Fixed the problem!
gman300zxtt
01:59:34 06/29/15
